Low speed orifice removal 77 115 johnson
whitejamie99
Removed the carbs while waiting for my rebuild kit. Noticed that the low speed orifice screws are badly stripped. Looked like someone used a small screwdriver and now they look pretty tough to remove.<br /><br />How do I get them out now? Or do I just leave them. This boat has had some neglect and I'm trying to redo everything I can and I really would like to fix this.<br /><br />Jamie<br />Learning more every time I look at this motor!
mikeyzx2
Re: Low speed orifice removal 77 115 johnson
Jamie, you and I are in the same boat (no pun intended) I would leave them alone just soak the carb and blow it out with air hose. I got mine out but there's nothing more you can do after that.
Navgunner
Hey fellas,<br /><br /> I rebuilt my carbs this year, but I started out without the right tools. I stripped out two of those jets real quick with the wrong screwdriver. I ended up drilling them out (VERY carfully) really just a small bit through the middle of the jet (so as not to foul the threads) The drill bit had enough bite to back the old jets out of the hole. I ordered the correct tool and new jets and proceded with carb rebuilt (just make sure you don't leave any filings!) Note to self: When the book says "Use correct size screwdriver or OMC special tool ..." Having 50 different screwdrivers does not mean you have the "correct" size! oops!
