How do I disconnect the oil injector?
CJY
I want to remove my oil injector and premix the gas, but I do not want to screw anything else up by disconnecting the wires that might be needed by the fuel pump. What procedure should I follow to successfully remove the oil injector?<br />Thanks,<br /><br />John
CJY
Re: How do I disconnect the oil injector?
I don't know if it matters but the motor is a 1989, 70 horse Johnson.<br />Again, thanks for any help,<br />John
DHPMARINE
You can remove the oil line at the engine,and plug the engine side of it.Premix is now needed.<br />The wires only affect warning systems,disconnect them too.<br /><br />Just realize the oil pump is also the fuel pump.It's one unit.<br /><br />So if you don't trust it to pump oil,why trust it to pump gas ?<br /><br />DHP
CJY
Thanks DHPMARINE, but am I hearing you say that I should continue to run and trust it? I guess I have heard more negative than positive regarding the oil injector. Although I have been around boats my entire life, this is my first that I have owned and I have alot to learn. At this point, I am going on what I am hearing.<br />Thanks,<br />John
dajohnson53
John, speaking as someone who pre-mixes, I'd advise you to stick with the oil injection unless you have a specific reason to disconnect it. My opinion is that what you're hearing is not the quality of information you think it is.<br /><br />My opinion after premixing for a few years is that there is always the risk of screwing up the premix and this risk is similar or maybe even greater than the risk of a modern oil injection system failing. Both are small, close to nil. <br /><br />I believe if you research on these forums as well as true experts -rather than listening to a few casual outboard users or enthusiasts, you will find that most if not all of the "stories" you hear about oil injection failures are (1) not oil injection failures at all, but rather carburetor or other fuel system failures (a carb failure can reduce lubrication and fry one or more pistons and is often mistaken for an oiling system failure) or (2) caused by complete negligence in basic maintenance of the oil injection system. The systems do indeed require some basic monitoring and seasonal checkup/maintenance - but from what I've seen and read, many people just don't do anything. Any system needs proper maintenance to function. I feel the maintenance and diligence required is no more significant than the diligence required to properly measure and mix pre-mix oil. Both require some attention, about equal in the long run. No matter what anyone says, pre-mixing ends up being a hassle and is messy. Sure it's not a HUGE hassle or a BIG mess, but nonetheless, those factors are there and compare to the hassle of maintaining an oil injection system.<br /><br />Stick with the oil injection system. My engine is a remanufactured/rebuilt - and I believe they just didn't bother with the oil injection components and went with pre-mix. I'm almost ready to take the plunge and try to get the oil injection set up for the reasons I've mentioned. (But it costs some dough!).
WillyBWright
Many problems I've seen involve oil tanks exposed to the elements. It should be in a protected area. If water gets in there, it'll settle to the bottom and get sucked up rather than oil. Outcome is predictable. But I don't recall coming across one single VRO failure that didn't involve gas too.
dajohnson53
Originally posted by WillyBWright:<br /> ... But I don't recall coming across one single VRO failure that didn't involve gas too.
I don't understand?
WillyBWright
It pumps both gas and oil. If there's a problem pumping oil, there's usually a corresponding problem pumping gas.
hooksetter62
running out of gas wont burn up your engine,running out of oil will do bad bad things.
DHPMARINE
I don't have all the facts,but we went along time without electricity (WAY BACK when it was new)(read EDISON) people were afraid to have wires over their heads.<br /> Might hurt ?<br /><br /> Omc started using VRO back in 1984.I'm no longer afraid.Seen maybe 2 failures ,but I think 1 was to satisfy a customer who was wrong.(talking oil failure)<br /><br /> As I have said before I keep reading about Merc's having gear failure on their crank driven pumps.They probably do.May see 1 one day.Show me some stripped nylon gears.<br /><br /> Basically neither system worries me.<br />I just don't see a lot of breakage because of this<br /><br /> Just an observation.<br /><br /> Happy Holiday All !<br /><br /> DHP
