Re: Johnson 40HP 1970 electric shift neutral
The one I've got looks like this:<br />
<br />It screws into the top of the bottle of oil, and the fitting on the end of the tube fits the screw hole in the lower unit. <br />They also sell oil in squeeze bottles for which you don't need the pump, but the pump really makes it simple and far less messy. Probably costs them $1 to make, they sell for about $10, but they're really priceless if you value your sanity.<br /><br />What you need:<br />2 nylon gearcase plug gaskets (pick up a few from the dealer so you have them for later)<br />1 Pump<br />450ml or so 'Premium Blend' lube.<br />1 large slot screwdriver.<br />1 old bucket to catch the old oil.<br /><br />How you do it:<br />1. Place the bucket under the gearcase with the outboard in the normal, "down" position.<br />2. Remove the bottom large slot screw ("Fill") on the side of the 'skedge' or fin on the bottom of the gearcase. Oil will begin to drip.<br />3. Remove the other large slot screw ("Vent") on the side of the lower unit just above the flat plate above the propeller. Oil will flow more quickly. If the outboard is a manual shift, do
NOT remove any phillips head screws.<br />4. Wait for the oil to drain out. Examine it for chunks of metal or signs of water. If the oil comes out the colour of coffee with cream, it's got water in it. If it comes out like black coffee or the colour of honey, it's good.<br />5. While you wait for it to drain, fit new nylon washers on the "Fill" and "Vent" screws. Discard the old ones. They might stick to the lower unit and need to be dug out with a screwdriver.<br />6. When the gearcase finally stops emptying, put the pump on your oil bottle, and screw the other end into the "Fill" plug screw hole. Pump away slowly until oil comes out of the "Vent" hole. <br />7. Put the "Vent" plug in and tighten it. Remove the oil pump fitting and quickly install the "Fill" plug. Not much will drip out due to the "Vent" being pluged. Tighten the "Fill" plug.<br />8. Clean up, dispose of the oil. Make sure you put roughly 450ml into the gearcase.<br /><br />If you've got any questions, just ask. It'll probably take about 1/2 hour the first time you do it, 15 minutes the next time.<br /><br />Good luck!
