flexon_guy
Thread starter- Joined
- Sep 15, 2004
- 81
I have a 35hp long shaft 76 Evinrude that is kicking out of forward gear at about one third throttle. It kicks out of reverse at about one half throttle. When I went to drop the lower unit to rebuild I noticed that the lower connecting rod bolt was different than the top and think that it may not be the original. I then noticed a small amount of play in this bolt allowing the lower shift rod movement before shifting into desired gear. I removed all the play and retightened this bolt and retried the lower unit which did not seem to change its kicking out of gear condition much. <br /><br />After removing the lower unit I noticed that the lower shift lever was turned out almost one full turn which would have caused this shift rod to be longer than if it was fully seated in the lower clutch yoke. It also seemed as though it may be bent. When twisted as beeing unscrewed from the yoke the top made a circle the circumfrance of a dime.<br /><br />My question is does it appear as though the lower shift rod is my problem? Would I be wasting my time to source a new lower shift rod and reinstalling the lower unit on the motor/boat to see if this works before procedding with a complete lower unit rebuild?.<br /><br />History of the motor is unknown and the gear oil was dark in color with green hues on a white background with no burt smell. If there was any metal shavings they went unnoticed in my cup.<br /><br />Thanks<br /><br />Mike
