Decarb
71whaler
I want to run a decarb on my 1983 75HP Evinrude using Seafoam and have read through the FAQ. Currently I have a quick connect fuel hose that runs from the portable tank to the fuel/water seperator and then a hose to the engine. Can I run the seafoam mixture through the fuel/water sperator or do I need to buy another hose?
rwise
Re: Decarb
I would not see a problem with the water separator. Just follow the directions, and maybe change the plugs when done.
dajohnson53
Re: Decarb
Every time I've done it using the "tank" method, I've run it through my water separating filter. It sure smokes and smells like the Seafoam is getting to the engine! I don't think the water separating filter can separate anything that's actually dissolved in the fuel (e.g. oil, Seafoam, other fuel additives) - it is designed to separate undissolved water and particles.
duck64
Re: Decarb
after you decarb run a can in your tank about every 5 tanks, you will be amazed how much better it runs. i do mine every season like D. does.<br />good luck
