sprouticus
- Joined
- May 12, 2005
- 208
I took the head off my boat recently, had to have a helicoil installed. While it was off I cleaned up the carbon that was on the piston, and checked the cylinder wall for damage (didn't find any). I wiped down the cylinder wall with an oiled rag, put everything back togeather, and took her out for a run. She ran pretty good..............that was last week. Yesterday I had it out for the day and it died, leaving me stranded in the lake.<br /><br />Some background information........I have a 1977 70 hp evinrude. I use 2, 20 litre gas tanks. When the motor died it was just after we ran out of gas on the first tank. I was in the tube at the time so my buddy switched tanks and went to start her up again. She turned over and started briefly, and then died again........and when he went to turn it over again, it wouldn't. I came in and hooked up the electronics battery to help jump the motor battery.......the motor still wouldn't trun over. So I wrapped a rope around the flywheel, and figured I would turn it over that way (I've had to do it before.this is why I have a extra battery for the electronics
) Anyway the flywheel would not budge. I tried to turn it by hand, and could hardly move it. It was in neutral, it should have been fairly easy, but I could barely move it. Oh, and the gas was mixed properly, and the motor was not too hot when this happened (I could feel heat, but could leave my hand on there forever). I am about to pull the head again and check for scaring. Any suggestions guys???? I am assuming I am in for a lenghtly rebuild that I cannot afford..............sigh ..........sucks to be me.
