Re: Newbie with an Evi
Chris,<br /><br />The "Oil Level" plug you are refering to is for the lower unit grease. Actually there are two of those plugs, an upper and lower plug. You should go ahead and change your lower unit oil just so you know you have new in there. This is inexpensive and easy to do. <br /><br />Both those plugs look about the same. They are about the size of a time and have a slot for a straight edge screwdriver. Be careful not to unscrew any of the other screws because one of them might hold your shift linkage in place and is a "bXXch" to get back in place.<br /><br />Remove both plugs and drain the oil out of the lower unit. Pay attention to the what the oil that comes out looks like. If it is milky, it could be a sign that watter is getting into the gearcase through a bad seal. If you see this, change the lower unit oil again after you first trip out and see what it looks like.<br /><br />Buy "outboard lower unit gear lube" oil from just about anywhere. This is a picture of what I use:<br /><br />
http://www.outboard-boat-motor-repair.com/Johnson 5.5 HP Seahorse Outboard Boat Motor/Remove33.jpg <br /><br />With both plugs out, stick the tip of the lube container in and squeeze the oil into the lower unit untill the level comes up and oil starts comming out of the top hole. At this point, quickly put in the bottom plug and then the top. Hopefully you have your plugs back in before too much oil drains back out.<br /><br />All the small Johnson/Evinrudes are quite similar. You might enjoy reading and learning about a couple of mine at
http://outboard-boat-motor-repair.com Also, do a search on 4 HP in this forum and read wome old posts and you will learn a lot. Don't heasitate to ask questions as there are plenty of helpful people here.<br /><br />Hopefully you will get to the point where you will be able to tune up your motor and then you will have someting you can enjoy.
