Hi guys a newbie here. I just bought a 77 Alumacraft Trihull with a 69 Rude 55 electric shift. It had a cracked lower unit which I am replacing with a lot of new info from this forum. I've got a question about the input shaft or whatever its called. Does it need to be greased with anything before I put the lower unit back on. If so, what kind. This is my first boat/motor so I appreciate all the info from you guys. Is there anything else special I should know before I put this on? The water pump tubes (I think thats what they are), the gasket, and the wires are all in place. Any help is appreciated.
