Cause of low compression
miket
Johnson 115hp 1998, trouble starting and idling.<br /> running hot. Replaced water pump. <br />Top right cylnder 95 other three at 110<br /><br /><br />Removed head to replace gasket to find damage to top right piston and head. Appears a chunk of metal dislodged and banged around dinging the head abit, and gougint the piston. Appears to be a chunk of the edge of the piston. I can see top ring which appears in tack, but the piston around this edge looks deeply damaged.<br /><br />What should I do?
sikpnter
Re: Cause of low compression
Not much of a choice here buddy sorry. How bad is the cylinder wall damaged?
R.Johnson
You are probably looking at a broken ring here. The only fix would be a rebuild. Depending on how much damage to the cylinder wall. If you do a rebuild, you will want to get to the bottom of the problem that caused the damage. Lugging the engine at to low a RPM would be one cause. You will want to look over the entire system on a rebuild, carb's, sync, and link, ign, or let's just say the works. We can help you along with yor questions. If you have to, you can go .040 over on a rebore if you use Wiseco pistons. Let us know as you go along.
miket
^The cylnder wall look good, Can I just replace the one piston?<br /><br />RJ what does lugging engine at low rpm mean?<br /><br />Should i buy remanufactured powerhead?<br /><br />Mike
R.Johnson
If you are running a prop with to much pitch, it won't let the engine come up into it's power band, or let's say, it's proper RPM range. It would be like pulling a heavy load with your car in to high a gear. This is what lugging means.
Solittle
Yes Mike you can replace just the one piston. After you have it apart take it to a marine machine shop. They will bore the one hole. Oversized pistons are available and this is a common repair.
