Re: Engine locks up when warm Cold does fine
OK pulled the thermostats and checked them. They both open well when heated. Opened up the water passages on the back of the motor and they seem clean. I don't think it is a dirty passage problem. Next step is to pull the impeller and see what it looks like... Could someone tell me if the 4 89psi cylinders are within spec on this particulart engine. The way I see it I have two cylinders with problems. The 62 and the 70.
