dcraton
Thread starter- Joined
- May 24, 2005
- 7
Motor starts fine, usually first crank. I have replaced fuel lines, cleaned fuel path, cleaned carbs, new plugs, new gas tank, ran Sea Foam through it, used Berryman's, and even spoke nicely to it.<br /><br />I loaned the boat to my dad, and he had to replace the shifting and other cable to the carbs from the console. Since I have gotten it back, it has run so inconsistant when I try to accelerate and it will no longer run at full speed, maybe 3/4 at best and intermittent. Could the linkage on the cable and carbs be out? Or should I look at tearing the carbs down and cleaning those?<br /><br />In a bit over my head here, and thanks in advance.
