McGR
- Joined
- Jun 19, 2004
- 667
Re: Power Pack Question
MD- You say 12V is getting to the power pack. Where are you measuring 12V? There should not be any battery voltage present at the power pack. This ignition system operates from induced voltage created by the moving flywheel magnets and the sensor and charge coils. The battery is only present only for cranking and operating accessories, but not for providing a voltage source for the ignition module (powerpack). This is why you can a motor with style ignition with only a pull start, even with no battery present. If battery voltage is indeed present at the powerpack, this could explain the problems you are experiencing.
