Re: 1972 25hp rude spitting and sputtering
After iddle, the plugs will usually be black on those.<br /><br />Try to adjust low speed iddle mixture screw, like this, quoting Joe Reeves, with boat in water, start by seating needle gently ( never with force) and backing out 1 1/2 turn, then after running WOT for a couple of minutes to warm motor up, let motor push boat unrestricted forward in gear:<br /><br />(Low Speed) Slow the engine down to where it just stays running. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
