76 Johnyrude fuel line config
promotec
My 76 johnyrude needed the water sep filter replaced so I thought I would do fuel lines and bulb as well while Im at it.<br />The old config was <br />motor-water sep filter-priming bulb-tank<br /><br />on the new water sep filter it says its to be mounted between the priming bulb and the tank.<br />(unlike how it was setup)<br /><br />should the priming bulb be between filter and tank or between motor and filter?<br /><br />The new water seperator filter is a sierra one it doesnt have the little screw water release at the bottom just a filter like a car oil filter, do these have to be emptied regulary by removing then putting the filter back on,<br />or just say once a season by replacing the filter element with a new one.?<br /><br />Thanks in advance for any help on this <br />Regards Chris
promotec
Re: 76 Johnyrude fuel line config
this is a 115 v4 1976
