JOHNSON 2001 COMPRESSION
COLT51
THEY CANNOT FIGURE OUT WHAT THE COMPRESSION SHOULD BE FOR MY MOTOR (2001 JOHNSON 175 OUTBOARD). I WOULD APPRECIATE ANY ADVICE YOU CAN SHARE WITH ME. ALSO, DOES ANYONE KNOW WHAT THE COMPRESSION IS ON NEW JOHNSON OUTBOARDS?<br /><br /><br />THANKS IN ADVANCE...RON
Dhadley
Re: JOHNSON 2001 COMPRESSION
Welcome!!<br /><br />Who is "they"??<br /><br />The compression should be even -- no more than 15 lbs different from high to low.
G DANE
Assuming it is a V6 looper, I think something around 110 - 115 is quite normal. Some of these motors run with "low compression" headgaskets, lowering compression to around 95 - 100. But as mentioned above, all 6 showing equal figures is more important, though numbers lower than 90 would worry me.
COLT51
THANK YOU FOR YOUR REPLY...JOHNSON/EVINRUDE/OMC COMPANY WILL NOT DISCLOSE TO OUR DEALER/CERTIFIED MECHANIC THE PROPER NEW COMPRESSIOS SPECS. BEWARE OF BUYING THIER MOTORS DUE TO THIER LACK OF CUSTOMER APPRRICIATION.
Dhadley
Obviously youre talking about Bombardier but OMC didnt print that either. Thers way too many variables like gauges. Thats why they've always said to look for no more than a 15 lb variance.
