Had a repeat problem the past two weeks, however, after each incident the engine ran fine once I reset the gap on the spark plug. In each case the spark plug electrode was smashed against the anode. At first I thought maybe a piece of whatever (reed valve, ring?) made it way in there and just happened to hit the plug. Seems unlikely being that the plug was struck again a second time. Highly unlikely a small piece of metal would hit the same spot before making it's way out the exhaust port. Compression isn't perfect, but not bad. 100/90/100/90. The problem cylinder is the top starboard cylinder, it reads 90 psi. I've heard this one also generally runs the hottest. I have a pickup on that cylinder and on the top cylinder on the other side. It seems to have been running slightly hotter this year, but nothing excessive or off the scale.<br /><br />Runs strong, idles fine.<br /><br />Both times this occurred it was at the end of the day, 4 pm roughly, heading back from fishing. The engine was cold (off for 3 hours each time). The trouble struck within a minute or so of running about 4000+ RPM. Is it possible there's some sort of rapid expansion that's going on that would cause the piston to hit the plug. I have spark plugs with a curved arm as the electrode rather than the flat type plugs. Not sure the numbers on either type, but I had the shop put the plugs in that are in there, and they said they're the right one's and I've been using them for years with no problems.<br /><br />Any ideas?
