No water coming out of Pee hole
Anglin Texas
1990 150XP E150STLESB<br />No water coming out of peehole, pulled the lower unit off, pulled the water pump off, and havent found anything wrong. Can pull the pee hole tube off and can easily blow air through it. On the water tube going up the mid-section, can this come loose? Doesnt feel loose. Thanks!
papasage
Re: No water coming out of Pee hole
the spout it hooks to is it open . thermostat stuck .
Anglin Texas
i can hook the water hose to the spout (tube) and i get water comming out of the telltale. It's always started peeing as soon as it starts running in the past. Where is the thermostat on mine? I'm in search of a manual right now.
Blueclaw
your thermostats are on the upper portion of your heads water jackets. you have two. <br />Did you run in any mud or the likes?<br />does the motor feel hot or did the alarm go off?
Anglin Texas
I didn't run through any that i know of. when i pulled the pump apart it had a little sand in it. It never ran hot that i know of and the alarm never went off. The last time i was out it worked fine. Then My power pack started messing up and it fires intermetley (spelling?) but it decided to fire fine when i was testing it, so i fired it up and it wasen't peeing (had the muffs hooked up) if i turn the water hose on high enough it will shove water through but it's not pumping it.
Anglin Texas
the plate under the water pump is worn, the perpeller looks good. I pulled the thermostats, At the rear of the engine facing foward the thermostat on the left is good, the one on the right is stuck about an 1/8th of an inch open. The thermostat cause it to stop peeing? (i know the pump needs to be rebuilt or replaced, but wouldn't it slowly stop peeing instead of all at once?)
