1990 Johnson 90hp. Recently rebuilt. The previous owner replaced the starter with a rebuilt.<br /><br />I was having trouble with the starter gear (bendix?) or whatever it's called - the one that pops up - sticking occasionally. I greased it with some white lithium grease.<br /><br />The next time I took it to the lake, it'd pop up but then something in the starter motor would spin, but not turn the motor over. I had to use the pull start.<br /><br />I tried it occasionally over the weekend and I was able to use the starter a few times, but mostly had to use the pull start. I put a battery charger on the battery - it was fully charged. I tried my recently charged trolling motor battery, same situation. Sometimes, if I just shut off the motor it'd start again with the starter, but mostly not.<br /><br />It never had this problem before I greased the shaft on the starter, so I'm guessing it's a self-induced problem. But what's the solution? Do I need to take the starter off and clean it? Is there too much lube inside the starter? Is it shot and I need a new starter? <br /><br />I searched the forum and found many recommendations to grease the shaft so I thought it'd be OK.<br /><br />thanks for any help/opinions
