nickeedunn
Thread starter- Joined
- Jul 18, 2005
- 3
I know nothing about engines and have just moved down to Oz and bought a 16' half cab with a 1976 60 HP engine. The engine, in the last 2 times when out, has been spluttering and when giving throttle cuts out, unless you give it time. With the first mix of fuel we screwed up and added 125:1 petrol to Oil instead of 50:1 (don't know whether this could be the reason for engine failure?). Anyway, I took it out on the water, same old spluttering, then mid speed all hell broke loose, and it sounded like we had hit bottom (which we hadn't) and the engine kicked up and stopped. On further inspection, the fly wheel (?) won't turn a bit and the props that used to spin freely if you moved them by hand don't move an inch. When trying to start the engine, it just 'clicks' as if something is seized and the small cog wheel that try's to spin the larger fly wheel just jumps up. Has anyone any ideas - is this a major problem ? Will a professional servicing be required. Thaks in advance of any help. Nick.
