BarryBarrie
- Joined
- Jul 19, 2005
- 3
I have a 1988 Johnson 70 HP (Model number CJ70TLCCA) with VRO. Symptoms are: On the first run for the day, i.e. cold start and 5 minute warm up, the engine idles perfectly. Then throttle up it will max out at some low RPM, guessing 2500 rpm (no tach.). The boat will not plane. It will hold this condition for a few minutes and then like a switch will kick into full power and away we go. It rarely repeats this condition the same day and not until the next morning will I experience this again.<br /><br />Sometimes when it is about to kick into full power, you can tell it is about to happen as there are short intermittent burst of power for a fraction of a second.<br /><br />The owner's manual explains the function of the RPM limiting safety feature to protect the engine from burning out from lack of oil or over temperature and I suspect the problem is related to this protection feature. However, I am at a loss on how to diagnose or trouble shoot to confirm this. The over temperature alarm does work (found this out when the water intake once plugged with weeds) but is not sounding when the low rpm condition exists. <br /><br />This condition was first noticed 4 or 5 years ago (very minor) and what worries me is that it is taking longer each year. The oil consumption seems normal.<br /><br />The surprise last year was that the first run after taking from storage and the (very embarrassing) smoke was still thick in the air from burning out the winterizing fogging - not a problem! Full power right away. But the next day was a different story.
