TBarCYa
- Joined
- Apr 13, 2005
- 781
I have a 1985 Evinrude 90hp engine that when I started it yesterday ran find and was running at 3/4 throttle for about 15 minutes when it suddenly bogged down and from then on it will run terrible above half throttle. Initially, pushing the key in (activating the choke) would allow the boat to get up on plane and half throttle (without the choke) would keep it there, but it stopped being helpful after a short time. I took the carbs apart and blew cleaner thru all of the orifaces and adjusted the float level and everything is clean and the floats are adjusted properly.<br /><br />I'm looking for suggestions on what may be causing my problem. I have a set of recently rebuilt carbs that I can install but I'm not sure that the carbs are the problem since they are clean and seem to function correctly.<br /><br />Someone suggested that it could be a timing issue but I don't know how to adjust the timing on this engine.<br /><br />Any suggestion on what may be the problem would be very helpful. <br /><br />Thank you in advance for your assistance.
