90Hp V4 1990 Evinrude GOOD??
tengals123
Guys what's you opinions on this motor?<br />Is there something I should look for?<br /><br />cheers
Dhadley
Re: 90Hp V4 1990 Evinrude GOOD??
Thats just the good 'ol V4 crossflow. Old but very reliable technology. About the worst thats going to happen is that the motor was lugged and broke rings on the starboard cylinders. Easliy preventable.
tengals123
so, if i check the compression before buying it, all 'should' be ok?<br /><br />cheers
lark2004
Ahhh, Comeing over to this side eh?<br /> <br />Yes, a compression test is always a good idea before buying a second hand motor.<br /><br />Don't worry too much about the actual values, the important part is that there isn't any more than 10 to 15 psi difference between the cylinders.
tengals123
lark, yeah, im trying to get some advice on a new motor.<br /><br />cheers
tengals123
blown!!!!<br />im looking at a 89 fully rebuilt evinrude<br /><br />cheers
G DANE
I thought this might be helpfull to some people, mayby even as a part of FAQ's:<br /><br />Buying a used outboard motor.<br /><br />What to look for when buying a used outboard motor, to avoid just getting an expensive ancor, or a motor someone sells to avoid an expensive repair.<br /><br />Buying new, with dealer warranty is always safer, but here’s what I do.<br /><br />1: A sea trial on the boat the motor was previously run on, is always the best. During this trial, run WOT for at least 10 minutes, and hear the motor idle smooth afterwards. Observe how the motor responds to throttle up thru the different RPM ranges.<br /><br />2: When sea trial for some reason is not possible, my bidding price would lower accordingly.<br />Ask if seller will give any kind of written warranty ?<br /><br />3: If it is possible to hear is run on a stand, you will always know its able to start, but on a multiple cylinder 2 stroke motor, its very hard to determine that all cylinders run at all, and harder to know if they do their part of the work. Run the motor and listen for unexpected sounds, if you hear any, be suspecious.<br /><br />If I have to buy a used outboard anyway, here’s what I look for:<br /><br />A: Compression. Remove all spark plugs and take a compression reading in each cylinder.<br />Readings should generally be above 100 Psi on all, and within at least 10 PSI, best within 2-5 from eachother. Most healthy crossflows are around 125, loopers around 140. Some V6’s have compression around 95, though. Look for equal compression in all cylinders.<br /><br />B: Spark test. Remove all spark plugs, and connect a spark tester. All sparks should be able to jump a 3/8 gap at start motor RPM.<br /><br />C: Lower unit check. Remove lower unit drain plug, and check that oil is clear from water and metal deposits above “metallic” grain size. Check shift operation without any binding. Milky white oil is an evidence of water intrusion.<br /><br />D: If Trim and Tilt, Operate it up/down.<br /><br />E: Look for any broken metal parts.<br /><br />F: Why is this motor for sale ?? Could there be a hidden reason.<br /><br />G: Used or abused. People who care for their things and have them regularely serviced, usually cares for the outher too. If everything looks neglected, the required maintenance probably was never done too.<br /><br />I: Ask for service bills.<br /><br />It is hard never to take any chances, when buying used, but the above simple checks will help.
tengals123
thanks for the post, food for thought.<br /><br />cheers
surfduke
I just bought a boat with that same motor Evinrude 1990 90hp<br /><br />How is the broken rings easily preventable?<br /><br />Thanks,
Marc J.
Hey Surfduke, I feel sure Dhadley would recommend you to prop it for 5800 rpms or so @ WOT. Also decarb atleast once a year. Dhadley is the crossflow guru.
surfduke
I am a noob.... I have no idea what...<br /><br />
means....<br /><br /><br /> :(
Dunaruna
Surfduke, changing the prop to a different pitch will affect the wide open throttle (WOT) revolutions per minute (RPM). An quicker way to type is - Prop for WOT.<br /><br />Decarb = Decarbonize. Run a cleaning fluid through the carburettor or throttle body, the fluid will flush out carbon that has built up over time.
