Re: G Dane,Paul Moir Help please...
Hello rosco,<br /><br />it definitively has a thermostat !<br /><br />It is under the thin cover plate.<br />You must remove this and you will see.<br /><br />If the thermostat is calcified it normally won't open anymore.<br />It only will open - the whole valve will move against a spring then - when water pressure exceeds a certain level.<br />This is a failsafe function.<br /><br />It's a hard job to remove the cover.<br />Be careful the plate won't get broken.<br /><br />Nordy
