hamburger faces
- Joined
- Jul 28, 2005
- 2
I have a 1995 150 Fast Strike with a bad attitude. Heres the problem: Motor when cold will start right up and run perfectly. If I fish a spot quick for say 10 minutes or less it will also start right up and run fine.... Stop and fish for any longer motor starts right up but has no power and kills as soon as its under load at lower RPM's. Takes about 6-10 tries to get it going..once it gets past the low-range RPM's it will once again run fine but problem will repeat here and there throughout the day. Fuel primer bulb will not retain hardness either. I replaced the primer bulb and fuel line. Checked the vents in the tank, cleaned the air filter, cleaned the fuel filter, made sure there wasn't an air leak at the fuel pump, replaced sparkplugs,etc. I would assume I obviously have a fuel delivery issue.. Could it be the fuel pump? Vapor lock?? Any input would be appreciated.<br />Thanks
