Hi All<br />I need some helpful advice. I have a 1985 Smokercraft Big Fishermen Boat with a V Hull it is 15.5 ft long. It has the original 25 HP Mariner on it. This boat is rated at 50 HP and the 25 just was not providing enogh power so I purchased the 50 HP Jounson. <br />Now the questions<br />The 50 HP needs to be mounted with bolts thru the Transom. The current motor did not mount this way so I will need to drill holes
I have never done something like this, is this something a person can do or does it need to be done by the dealer? <br />If I had the steps required to do this I think I would be willing to try it.<br />So how do I determine where to drill the holes?<br />I am sure it has to do with the motor height which should end up with the cavatation plate being within 1 inch of the bottom of the boat correct?<br />What type of bolts should I use washers etc. <br />I have read to use 3M 5200 silicon?<br />And I am sure a bunch of stuff I do not even know about.<br />Any help is greatly apreciated<br /><br />Jerry
