power tilt question
aanda6
Have just got hold of a calco power tilt. Managed to rewire and get it working. Question is, seem to drain the battery really quick if motor is not running. Is this normal ir do I have a problem? any help would be appreciated.
aanda6
Re: power tilt question
no battery is fully charged. Have tried two different ones.Only seem to have enough to lift the rams once.
CJY
I'm with upinsmoke. A bad battery may appear to be good, but it is not necessarily true even though it holds 12 amps. The bigger truth behind a bad battery is the length of time that it is able to hold that charge.<br /><br />If you had bad wiring that caused a good battery to drain in a matter of a few seconds, you may also be finding some smoking insulation on your wires.<br /><br />John
aanda6
Thanks yingling-j, I did have a small amount of smoking from the wires, just thought it was because the motor hadn't been used. Might have to replace all the wiring. Do you know if there is a particular gauge wire I should use
buddyholly
does the unit have relays or is it wired direct? that may put an excess load on the switch wiring.
aanda6
At tis stage it is not on the boat. i just got it last week and have replaced the seals and cleaned it up.Wanted to get it working off the battery before I wired it to the switch.
