misterguru
Thread starter- Joined
- Jun 4, 2005
- 55
Hi, I read posts here for two days before tearing into the motor on this bass boat. It is a 1984 150HP V6 Evinrude. <br /><br />The boat would only run in gear with the enrichment "choke" activated after buying it from a guy who had it stored for 4 years. Here is what we did:<br />* removed carbs and cleaned them with compressed air and carb cleaner<br />* plugged VRO pump and mixed gas 50:1 manually<br />* checked for spark at each cylinder<br /><br />Now the boat wuns in forward gears but only reaches 4200 RPM... that is OK, but at WOT you can hit the enrichment and BAM! It FEELS LIKE YOU DOWN-SHIFTED! I mean WOW! Then it reashed 5700 RPM holding in the enrichment/choke button.<br /> <br />So... we thought... maybe a fuel pump... but if I pump the bulb, it goes no faster.<br /><br />Thoughts?<br /><br />Is the fuel pressure raised with the enrichment?<br /><br />It must be something simple!<br /><br />Thanks!
