1984 150hp Evinrude, runs faster with choke activated on top end
Dhadley
Re: 1984 150hp Evinrude, runs faster with choke activated on top end
Do not try to remove the plastic fittings from the bowl. Just soak everything as per instructions.
misterguru
DH:<br />The things that look like freeze plugs are cupped and fit loosely into the old openings. I am assuming I need to use a vise, c-clamp or press to push the center of it and expand... just checking in here first. Is that right?<br /><br />Also, the kit has several parts I don't have... little white plastic caps with a smaller hole in them, red trim rings about 1/4" with "ears" on them... I hope this is just because one kit fits several years.<br /><br />Thanks!
Dhadley
The plugs go in just like you think they do. Set them in place and then tap the center with a hammer & punch. Then add your sealer. Dont over-think this (clamps, vices etc), just follow the directions in the service manual. These are very simple, easy carbs. Dont out-trick yourself.<br /><br />Youre absolutely correct. The kits cover several years and motors. There will be some extra pieces.
Basscat 1
Here is a carb video that shows how to rebuild carbs. Just click the link in the middle of the page that says, themarinedr.<br /> web page
misterguru
DH: I just have a Clymer manual from the library :)<br /><br />I guess a 1/4" bolt will work for a good punch?<br /><br />Sealer? Gimmee a clue and I am off to Autozone!<br /><br />Thanks Basscat, will go watch now!
misterguru
That's a great video, but my little freeze plug caps don't fit tight enough to go tap-tap with an extension and fit tightly...<br /><br />Well, I will go whack it some!<br /><br />Thanks for the video link.
misterguru
Well, I took a 3/8" extension and used the small end... like the video... whack! whack! and it stuck... cool.<br /><br />Opened the second kit, same thing... third kit... no brass freeze plugs... same part number on the bag, no plugs. So, I have to go to the dealer in the morning.<br /><br />Looks like Bombaider's QC is a little lacking... two out of three ain't bad for Meatloaf but for parts it sucks.
misterguru
It works! It works! It works! It works! It works! <br /><br />Yippee Skippy! Thanks all! :D
Dhadley
Good for you Tim!!
Basscat 1
This boards great. ;)
fireman57
Maybe I'll see you guys on the river this weekend. Wife just told me that she wants to go fishing early Sunday am. That means that I'll take her.
