Re: 1961 Evinrude Lark 3 help
The Evinrude/Johnson Big Twins are excellent outboards, overall. Very sturdy and with lots of torque. They're a little fuel hungry, but that's not a real problem.<br /><br />There were tons of these made, so good, used lower units and other assemblies are fairly easy to find. Outboard junkyards, like tcoutboard.com, are an excellent source.<br /><br />That said, what I'd do is pull that lower unit off the engine and check two things: Compression and spark. Spark's easy. You can replace the entire magneto system for around $50 with new parts. Compression's another matter. If both cylinders are over 80 psi on that engine and within 10% of each other, you're in pretty good shape, and the outboard's worth spending some money on.<br /><br />That basic engine, in one form or another, was made from the mid-fifties up through the late sixties, and beyond. What that means is that lots of experience exists on it and it was an excellent design.<br /><br />There are several owners of that engine or ones closely-related to it here, and there's lots of technical help available.
