KennyBradley
- Joined
- Jul 28, 2005
- 32
Hi,<br /><br />I have a 1986 70hp VRO Evinrude. While crusing at WOT she suddenly lost power and there was a rattling noise but she continued to run. I discovered she han no compression on no.2 cyl. Looking back I think I noticed she had been marginally down on power for the last couple of trips but it was't enough to worry me.<br /><br />On stripping the engine down I found no.2 bore badly scored, the piston was in a terrible state and the top ring had broken up and come away from the piston.<br /><br />I had assumed The reason for the early drop in power was a cracked ring which eventually broke up and caused the failure? All cooling passages where in good nick and the water pump was running well.<br /><br />Speaking to a parts dealer he said blocked main jets is a week point on these engines and if she ran lean the piston would seize before the bearings failed?<br /><br />If she had seized due to lack of lubrication Would she seize solid and stall or would she still be able to run on as she did.<br /><br />Any opinions would be greatly appriciated.<br /><br />Cheers Kenny
