Hello,<br /> I have a 1970, 85 HP hydro-electric Johnson outboard. I recently drained the lower unit for good measure, the oil was milky, so obviously water has gotten into the unit. To rule out just a cut seal behind the propeller, I filled the lower unit back up with premium oil, put the muffs on, and started the engine and let it run for a few minutes and then went to look at the oil and it was milky again, so I don't think it is just a cut seal behind the propeller. Also, when it was running, there was a little water coming out of the 2 holes just below the powerhead, so it looks like the water pump is working. I know I need to pull the lower unit off, and inspect all the internal components. I am wondering if anyone has any other ideas to test before I tear it down, and what could be wrong internally. I do have a manual, but I am still unclear as to what seals, ect. keep the water where it should be going. Could it be a cracked water pump, hole in the pipes going up to the powerhead, or are there any known problems with this engine that it could be? Thanks!!
