HYBRID HELP '90 115 + '95 115 powerhead
danlee987
I have a dead Evinrude E115TLESB 1990. The head gasket let go on #2 cylinder and the #4 overheated and rings disintegrated. OUCH!! I do have access to a 115 powerhead that supposed to be 1995 vintage. Is there any possibility of mating the lower 1990 with the 1995 powerhead????? Does it make any sense??
Dhadley
Re: HYBRID HELP '90 115 + '95 115 powerhead
If the 1995 115 is a crossflow, the parts will interchange nicely. If its a 60* looper 115, nothing is the same. Not even the flywheel nut. In fact the 60* doesnt have a flywheel nut, its a bolt now that you mention it.
danlee987
Thank you Dhadley. This helps me out greatly,as I needed to make a choice today. I have to apologize as while you were typing this out I retyped my topic removing capitals to tone down the request. I've thoroughly appreciated reading throught he advice given on this forum. Again, MANY THANKS!
danlee987
I went back to look again at the 1995 115, i only get 2 pictures of the engine which appears to be the same as mine. You mentioned that the flywheel connection was different. If this si true then it would be a crossflow engine. Do you have any more for me on this so that I can be more confident in purchasing this powerhead on ebay. Thanks
Dhadley
If you can see the flywheel, it is a crossflow. The looper wont even resemble yours. If it looks like yours, it is the same.
Dhadley
If you like send me an e-mail with the e-bay number and I'll take a peek. I wont bid aginst you -- I have no need for a V4.
Dhadley
I should say -- I dont need another V4!
danlee987
Thanks Dhadley, I bought her! I should have her back together for the Sept. longweekend. What compression should I get when I test it on arrival? I was going to ask seller to fog cylinders prior to shipping, is there anything else I should have them do prior to shipping?
