I have a 1984 Evinrude 235 on a 17' tri-hull ski boat. 14.25 x 23' ss prop. One powerpack has been replaced, and the timing has been set by the shop.<br /><br />Engine maxes out a 5000rpm. Speedometer reports 55mph. I am concerned that 5000rpm is too low.<br /><br />Engine runs good w/o load. Engine dies trying to pull up skier. Engines dies pushing boat onto trailer.<br /><br />My local mechanic has given up. I'm on my own!<br /><br />1) the fuel filter won't stay full (boat losing prime? air in fuel?). The motor-side of the filter says full, the tank side emptys in a hurry. I have tested the lines all the way to the primer bulb, all good. The bulb is new and installed by shop. VRO has been disabled, oil-inlet plugged. This is my biggest concern.<br /><br />2) is the prop to steep? The boat obviously planes faster and reaches a faster speed with fewer people, but the motor always reaches the same rpm.<br /><br />3) some water is leaking under the left-side motor mount. Should i look for an exhaust leak?<br /><br />4) cavitation plate is about even with bottom of boat. motor will vent in sharp turns.
