midsized johnson
- Joined
- Jul 28, 2005
- 155
Thanks Bubbakat for the SB. I installed the water outlet fitting at the top of the exhaust cover which makes more sense to me as the location for the tell-tale water outlet. When I ran the motor, I had a big increase in water pressure (10 lbs at idle). I still had the flow restrictor in the end of overboard indicator. I removed it and flow was more normal (2-3 lbs at idle). I believe the flow restrictor should be removed permanently. Anyway, for those interested, here's pics of the finished product.<br /><br />Port side of motor with overboard indicator and tubing at top of exhaust cover:<br />
<br /><br />Stern view, "tee'd" (white connection at top rear of exhaust cover)the outlet hose to water pressure gauge.<br /><br />
