1976 115 johnson lower unit removal
DEERSLAYER2000
Hey everybody, Thanks for the help on my 20hp motor, it took a new clutchdog to fix my shifting problem. Now a friend of mine needs a new impeller in his 115hp johnson and i can't get the lower unit off. Sure could use some help.... Thanks DS2000
Walker
Re: 1976 115 johnson lower unit removal
6 bolts and the shift linkgae. Do you have everything?
DEERSLAYER2000
i took out six bolts but can't figure out how take the shift linkage lose. The lower unit moves alittle and drop about 1/8 inch and thats all have got done
KYHunter
I just rebuilt my 1978 115 Johnson and if its like mine the linkage is under the intake in the center . Mine had a alignment ? screw , you just use a long screwdriver and take screw out and its unhooked. The lower unit will drop some even with it hooked up but I wouldn't leave it hanging on the linkage you may bend the shift rod.
DEERSLAYER2000
hey KY Do you mean center at the front of the motor?
KYHunter
Yes, if its like mine under the carbs you shuold see the shift rod sticking up to the linkage . Its a little hard to see, if you have someone move the shifter a little you may see it move.
DEERSLAYER2000
KY I looked up there but missed it, I'll look tomorrow and see if that is it.Thanks Is it hard to change the impeller?
KYHunter
No, I thought it was easy. Make sure to remember which way the fins on impellar are turned ,and to put back the same way . I lubed everything and it slid together easily. While your in there look at the drive shaft seal, mine was bad and I changed it too.
DEERSLAYER2000
Ky Thanks for all the help, I'm sure glad this place is here. I'll let you know tomorrow how it went. Thanks again DS
kevin88
Just a side not... On these older v4's there is also 8th bolt hiding under the trim tab housing. You have 6 bolts on the outside, one to remove the trim tab, and the 8th is in the underside (above and behind) where you pulled the trim tab off. And The shift linkage is under the carb behind the powerhead in a real tight spot.<br /> <br />Hope this helps.
KYHunter
Dont forget to change the "o" ring on top of driveshaft.<br /> Hope I was some help, and your welcome.<br /> KYHunter
DEERSLAYER2000
hey kevin Thanks Hey KY you a big deer hunter?
KYHunter
yes, I got a 140 inch 8pt. last year. I hunt 60 plus days a year for deer and more than that for coyotes and bobcats.
Captain C
I have the same problem with getting the lower unit out of my 1978 115hp johnson. I have taken out the six bolts. Two on each side, one in front of the trin tab and one underneath the trim tab. I have unhooked the linkage under the carb. The unit does not drop out. I have wiggled it back and forth. I don't dare pry to much on it afraid the cast aluminum will break...
Any and all help is much appreciated...
Thanks, C
TD_Maker
Captain. Tap it a couple of times with a RUBBER mallet. With all the bolts disconnected, it should drop out. We deal with this kind of problem all the time down here in Florida due to the salt water.
PNW Driver
Mine has the hidden bolt. I had to hammer for a while(carefully) with a rubber mallet and a chunk of 2x4 till I could get it to budge. I also had 4 bolts broke off because of salt water corrosion.
