60 johnson shakes
fish68
while motoring up the ohio i beleive i hit something, after that i could not go over 2500rpm without some serious engine shaking.<br />prop ok, no metal shaving in oil,sparks ok when i took out again ran great for 25-30 sec 3500rpm tjen motor bogs down and won't go above 2500 again, rested motor for 30 mins and same thing..not real mechanical just need possible ideas??? thanks..90 johnson 60 3cyl
rodbolt
Re: 60 johnson shakes
sounds like SLOW is on. test the overheat circuits and alarm horn. does the horn beep at you when you first turn it on ?
fish68
i am sorry but i am no mechanic...i will read anything i can and going to by a seloc manual...if you can give any bits of info, would be greatly appreciated..thank you for the reply..
