Hi all,<br /><br />Just picked this one up, <br /><br />The model number is missing off the transom bracket, and there is only a serial number on the freeze plug in the engine block.<br /><br />The engine's throttle is a lever that connects directly to the timing plate, and there doesn't appear to be any gear select.<br /><br />I have the engine dismantled already (why waste time?) as it was initially siezed up.<br /><br />There are no needle rollers at all, everything is supported by bronze bushes. (I know, 24:1 fuel mix).<br /><br />the cowling is the wrong one, says 4hp yacht twin. But it doesn't fit properly. It also calls for 50:1 fuel mix. <br /><br />Anyone want to have guess at the age of this little engine? I know it is pre 1964, not sure after that. <br /><br />
<br />
<br />
<br />
