Re: Where is thermostat?
The temp sensor,s are the ones with the tan wire,s. One on each bank.<br /><br />Yes they are what puts motor into SLOW. either one will do it....Hopefuly!<br /><br />You also have a t..stat in each head on v6 engines. T..stats have no wires.<br /><br />T..stats seldom stick closed. Nearly always they stick open.<br /><br />But if stuck open, they should be replaced. Motor running to cold will kill it also, just not as quick as to hot. But it will eventuly die.<br /><br />Motor should run between 125 and 175 degres. You can check with (melt sticks) auto parts stores have them.<br /><br />More than you ever wanted to know about a dadgumed t..stat...Huh!<br /><br />Good Luck!
