santuitman
- Joined
- Jun 26, 2005
- 14
Hello All<br />I have finally got back in the water after a few years and some help here! I recently rebuilt the carbs on this motor as there was gunk in them. I went for a short test run a couple weeks ago and it ran well but the idle wasn't too smooth. Yesterday I put in new plugs and turned the idle up a bit( while not running) hoping that when I got to the lake with the family it would be ok. Once in the water the boat would not idle. I could not use reverse as the rpm's would drop too low to shift. I could get going in forward by quickly dropping the high idle lever then slamming into gear before it died. Once in gear the motor ran well at any rpm over ~1200. As I wanted to enjoy the day I just didn't try to idle. At the end of the day it still wouldn't idle .(fun getting to the trailer!) <br />Any ideas what I may have done wrong or what else to check. I thought I set the idle mix screws correctly when I put on the carbs and when I set them it did seem to idle ok then. (on muffs)<br />Thanks in Advance for any ideas!!<br /><br />Brian Kelley<br />BTW After this season I think I'm going to have a real mechanic go over the motor so I'm hoping to just get the rest of the season out of it!(anyone recommend a mechanic on Cape Cod?
)<br /><br />Thanks again<br />Brian
