Re: 89 90HP Johnson. Where is the Tach lead?
I just hooked up my new tach and it works great. I'm no expert , but the tach gets signal pulses from the charge system . I'm not sure how this would show up on a meter. The grey wire is connected to a jumper thats between two yellow wires one of which has a stripe. The grey wire as far as I understand originates at the terminal strip . It is the sender wire from alternator to tach. If your motor is running and the grey wire is tied to one of the yellow wires your tach should work. I did a continuity test from terminal strip to control box to be sure my wire was still ok.<br /> If you want to test run a wire from terminal strip to tach and see if it works . If it does then your grey wire is probably bad.<br /> Good -luck,<br /> KYHunter
