caper_45ca
- Joined
- Jul 5, 2005
- 147
I recently posted a question as to why my piston ring broke on my 1995 90 hp v4 Johnson....well powerhead will have to rebored and rebuilt and after the teardown mechanic said it was full of black sticky goo and heavily carboned....manufacturer suggested wot to be 4500-5500..I could get 5100-5300 depending on conditions on any given day.....thought I was ok....but learned the hard way....(going to cost about $3000)anyway I was running a 13 3/4 x15 aluminum prop....I read on here where you suggest to setup engine to run 5600-6000 wot and get 35mph on a 18' sportcraft fish and ski bowrider...how is this done without re-propping.....if I do go to a lower pitch what would you suggest and what will this do to the top end speed?....one thing I forgot to mention...b4 this motor blew I was told by the original owner that there were less than 100 hrs onit....but anyway when I bought it a few months ago it was rough at idle...took it to the dealer and he set the timing at idle as follows..he did a link/sink and using the throttle advance adjustment he set timing to 4*btdc....Thanks again for all the help
