I have a 1973 70 hp evinrude that seems to have a water pump problem .The motor does not have a tell-tail . I just got done fishing and was flushing motor when I noticed the water was not coming out of the area above the lower unit nor was it spraying a fine mist from the 2 port holes below the cowling.<br /><br />After that I noticed a little white oil around the lower unit top drain plug and yes its got water in it(full) .Heres my question - can a bad water pump cause the lower unit to leak?<br />I did hit buttom(sand & muddy) twice at a very slow idle so that might be what did it.<br />Id like to try to replace the water pump myself however im not a mechanic so it will be a learning expereince.Please pass along any advice in doing it.
