1969 Johnson 75 hp lower unit trouble
timp6774
The clutch dog is out in my 1969 Johnson 75 hp lower unit. I can't find another of the same year that is also manual shift. Does anyone know what I could change it out with or where I could find the part for it?<br /><br />Thanks,<br />Tim
OBJ
Re: 1969 Johnson 75 hp lower unit trouble
Welcome aboard Tim!<br /><br />We need to get the year right first. There weren't no 75hp's in 69'. How about posting the model number so we can make sure of the year. Thanks!
Goodoleboy
Welt...heck son just turn at rascal around. You dont need much power in rarrevers.<br /><br />Lesin mabey shes wore down tu uh nub....! Grin<br /><br />Iam uh southern boy to...Ky..born an bred!<br /><br />If you need a new one.... mabey napa auto can find one. Or perhaps you can pick one up on E bay.<br /><br />Seriously tho...you can turn them around if its not totaly wore out.<br /><br />Luck tu ya!
steamboatwilly
Hi Tim,,,,Them things are expensive.I had a buddy had a motor bout like yours.I took a tig welder and build it back up ,then grind it down.It can be done if you cant find one,or like me, cant afford one.
timp6774
I'm sorry, I meant to put in 65 hp instead of 75. I guess I hit the wrong number. It is a 1969 Johnson 65 hp Super Sea Horse.
OBJ
Tim....I'll believe 68'. The clutch dog is still available from Bomby....far as I know. Last price I seen was about $95. Pricey.<br /><br />As posted above, a good machinist could square the dogs off but they do have to be the same on both sides. If the dogs on the gear are rounded, might get them done also.
