morrisstephen
Thread starter- Joined
- Aug 20, 2005
- 4
Well I'm still trying to line up my pinion gear with the drive shaft on my JOHNSON 140. <br />Rodbolt gave some good advice about checking to see id the housing pin is set. Can't tel if it is or not. I only have about 3/16" space to move the gear assembly forward. Which is about the same distance needed to get the pinion gear lined up center with the drive shaft. There must be some mechanicallocal knowlege to get this sucker in line. I would appreciate any advice!!!
