Re: Shift rod connector 1976 35hp
Well,folks...everything is perfect.<br /> Took it out today,and it goes just great.<br /> Without the help of you guys,this would not have happened.I was ready to drop the motor.<br /> When I took the compression readings,I had convinced myself to expect less from the motor,considering 12psi less,and the cooking I did.<br /> Today,it ran like a dream.I went easy at first,and found myself checking the pisser every 30 secs.<br /> When I opened her up,everything was great.from idle to WOT it went smoother and stronger.It even runs quieter.<br /> Before I cooked it,the top speed was 42kmph {about 26mph}.If you remember,I was working out the bugs in my link & synch set up .<br /> Today ,it got to 39kmph,which I was more than happy with.<br /> I put a can of Mercury brand sea foam stuff thru it,and I think it helped.It ran smoother and the speed nudged up to 43k {26.5 mph}<br /> And still with a crappy old prop !!<br /> My engine has NEVER run this strong,smooth or quiet !!!!!<br /> G Dane,you are a genius. This is the second time this bloke has pinpointed a problem for me. Many,many thanks to you.<br /> My genuine thanks to all you other guys who helped me with the link & synch problem,and with the cooking and subsequent shift rod postings.<br /> Fireman 57..OBJ..Mark a64..lark2004..nordy..Andrew Hartley... Serious thanks to all you guys.....every one of you constructively contributed to solving my woes. <br /> Anyway...as I said , it is simply running better than it ever has. Spring is just around the corner.<br /> La vita e bella. Life is beautiful.<br /> Thankyou boys.Another success
