Prop removal, first time.
FishMagnet
I hate to ask what is probably an easy beginner question, but I've had to many "Oh shoot!" times when removing things from motors etc... :)<br /><br />I'm getting ready to remove the prop off my Johnson Sea-Horse 40hp (rd-22) and was hoping someone could walk me through it to make sure I don't damage anything. Also, is a prop wrench required, or will a 1/16" socket (not positive on the size) work fine?<br /><br />Thank you,<br /><br />Matt
Paul Moir
Re: Prop removal, first time.
You hardly need anything but a pair of pliers normally. Actually, this is a real simple task on a Big Twin.<br /><br />1) Remove the black plastic 'cone' behind the prop by pulling out the cotter pin. It just pulls straight off.<br />2) Remove the drive pin that runs through the hub of the prop (which you just uncovered) through the prop shaft. If it's stuck, tap it out with a hammer and punch.<br />3) Observe or remove the thrust washer on the hub behind where the drive pin ran through. This is often found missing.<br />4) Pull the prop straight off. If it seems to be stuck, put the engine in gear to hold the propshaft. Then rotate the prop about 180° and pull. <br /><br />When reassembling, grease the prop, thrust washer and pin with marine grease. If the drive/shear pin has marred the shaft where it runs through making removal of the prop difficult, file the pushed out metal down so the prop slides on easily.<br /><br />I hope that's clear!<br /><br /><br />EDIT: Ah, a picture's worth a 1000 words:<br />
<br />There they are in the order of assembly. The first hole in the driveshaft is for the cotter pin for the cone, the second is for the drive pin.
CATransplant
Paul's absolutely right. There is no prop that's easier to change than the one on a Big Twin. But do buy and keep a couple of spare shear pins and cotter pins in the boat for emergencies. That's a must.
Paul Moir
Or like me you can be an unbelievable cheapskate and cut your own out of a piece of 1/4" stainless (ie, an old Big Twin shift-shaft). They're 1-7/16" long. :D
MYTJC
You might want to invest in a repair manual for your boat motor. I just bought one and its full of information about my 1985 Johnson 40hp. The fella's here always suggest obtaining one.
CATransplant
Yeah, Paul, but not everyone has a pile of shift shafts lying around. I noticed the other day that someone had recommended using roll pins. I can't remember if I advised against that at the time, since I was kind of busy.<br /><br />The shear pin's SUPPOSED to shear. Those spring steel roll pins won't shear. Good way to bust a gear or something else.
FishMagnet
MYTJC, I've got a service manual coming in the mail. (FINALLY!) I didn't want to shell out the $75 for one on the Ken Cook website so I patiently waited on eBay and got one for $14 (thats with shipping!). Took 3 months of waiting though.<br /><br />Paul, you're pretty hardcore. Making your own pins, and your custom brass throttle shafts. :)<br />Thanks for the walkthrough and the pic. The prop comes off tomorrow. If the thrust washer happens to be missing, do you happen to know the size so I can pick up a new one? Is it just a regular washer, or is there something special about it?<br /><br />Matt
Paul Moir
Now to get really off topic...<br /><br />Those Big Twin "shear" pins, just what does it take to shear one? Well, ultimate shear strength of a material is around 75% of the ultimate tensile strenght, which for 304 stainless is 90,000 psi. The drive pin is 0.25" in diameter, so it has a cross-sectional area of 0.05 square inches. Since there's two sides of the pin to shear, that means you've got to go through 0.1sq-inches of material. Which would require the application of about 6700 lbs of force (90000 x 0.75 x 0.1).<br />So what sort of torque are we talking about here? The drive shaft is 0.75" thick where the pin runs through, so applying 6700 pounds on a 0.375 torque arm (radius of the 0.75" shaft) works out to about 2500 inch/lbs, or about 210 foot/lbs.<br /><br />Worst case, the Big Twin puts out 40hp with the prop shaft spinning about 2300 RPM (4000 motor RPMS). Theoretically, that puts about 90 ft/lbs on the prop shaft.<br /><br />So, how about other materials?<br />Nails (low carbon steel, I'm guessing 1020) 160 ft/lbs<br />Brass - about 120 ft/lbs<br />316 stainless - 197 ft/lbs<br />1/4" Grade 8 bolt - 350ft/lbs.<br />Hardwood dowel - 16 ft/lbs. :) <br /><br />I have no idea what a roll pin would do (other than rust :D ) since I have no idea how much cross-sectional area there is.<br /><br />EDIT: Thanks for noticing the throttle links. :) The thrust washer is brass, 1-5/8 OD, 1-3/16 ID about 0.060" thick. It is supposed to allow the propeller to spin properly when the drive pin shears. I think you could find them easily at any J/E dealer or wrecker, but they're a little weird so you're not likely to find one at the hardware store.
FishMagnet
Well, the prop is off. You weren't kidding about how simple it was. Everything looks good, and the thrust washer was there. Found a massive amount of old fishing line behind the prop so I took that out.<br /><br />Did a light grind on the prop to smooth out a few nicks, nothing major. Sanded the rest by hand and am now waiting for the primer to dry.<br /><br />Its still the old prop, but it will look nice. :)
