PROBLEM!!!! 6hp Evinrude
Domofloge
Hey guys. Please help me. Its an older 6 hp motor. I just bought a brand new fuel tank, and the hose that connects the motor and the fuel. The end of the hose that connects to the motor isnt recieving the hose perfectly and when i pump the bulb to prime the motor, GAS SPAYS EVERYWHERE!!!!!!! Please give me some feed back... Anything is greatly appretciated...
Paul Moir
Re: PROBLEM!!!! 6hp Evinrude
Welcome to Iboats, Domofloge!<br />Can you provide the model number of your engine? There were a few different older 6hp out there.<br /><br />That said, have a look at the end of the connector. You should be looking at a silver ball and an o-ring between it and the casing. Is it present?<br /><br />If it's a defective fuel line connector you have, I'll tell you now the very best fuel lines, bulbs, and connectors are to be gotten from your Johnny/Rude dealer. No kidding!
Joe Reeves
Just to test that connector, plug it onto the fuel tank, then press the fuel primer bulb. If it still sprays all over the place, the hose connector is obviously faulty.
Domofloge
The only problem is that i just replaced the fuel hose. Is there any chance that there could be something wrong with the engine???
Domofloge
The old hose didnt do that. Should i return the old hose.
Fishon1
Just a thought. You maybe putting the hose end on backwards onto the motor. It is possible to put it on wrong and pushes the ball back enough to have gas come out.<br /><br />Try rotating the connection 180 degrees and see what happens.
Domofloge
Im pretty sure that i am putting the hose on right. But i will check it later on. I will post in a few days about the situation... Thanks to all that have been helping me... Im new to boating. Im only 16 and have alot to learn...
Paul Moir
It's almost definitely a defective new hose. With the ones you get from Walmart, etc, that's a suprisingly common occurance. OMC (Johnson/Evinrude) didn't make any changes to their fuel connector since the 50s.<br /><br />The dealer ones are $10-15 more, but the bulb & connectors will last a lot longer and the fuel line is way more flexy. Normally I'm the type to save a buck and avoid the dealer, but not with the fuel line. ;)
Domofloge
The problem is that i bought the new stuff... Put it on... Took it for a 2 hour ride... Came back disconnected everything... Then yesterday i want to go fishing go the plug it in then it starts spraying... Did i do something wrong???
Domofloge
Paul Moir
I don't think so. I suspect that the o-ring has slipped out of place or cracked, which would be a defect. If a return is impossible, you can just buy a new end-connector and clamp it on.
Domofloge
Ok Thanks all that help.. If any new problems arise i will be sure to rely on ya'll.. Thanks again guys and god bless!
