Re: Starter motor gear will not raise.
Hi Again<br /><br />Yes! she runs, and now back to draining the swamp. This motor was idle for a few years and the shifter did not work. My mechanic got it working by just using it for an hour and recomended frequent use. The boat then sat for another year and now I'm not sure how the shifter is working. On his recomendation I replaced the gear oil with diesel fuel and ran it gently for a few minutes. Now the type C oil is in. When I put it in gear with the ears on I don't hear clunk from the engine but the prop spins faster as I give it throtle. Should I put the boat in the water now to test it and exercise the shifter or is there smoething else I should do first? Again thanks to OBJ and Paul for seeing me through on this.<br />cheers<br />gerry
