swimmin' for shore
Thread starter- Joined
- Oct 25, 2004
- 490
I picked up an Evinrude last night. The idiot ran it on a broken impellor. It was probably a mistake to buy it, but it was very inexpensive. I've been fixing a handful of them, and I thought it would be worth the parts or a rebuild, if necessary. <br />Alright. This motor does not have a nameplate. Some idiot broke it or removed it or some such thing. I need to buy an impellor for it today, so I wanted to try to positively identify it here. I'll give you what I can remember from the short time I worked on it last night. <br />It's a 9.5 sportwin. White cover and blue motor. Shortshaft, if that makes a difference. The carbeurator is on the aft stbd. side. The gearshift handle shifts by moving it up or down. It's shifted from the forward stbd side of the motor. Very smoothly, I might add. The waterpump has 4 screws in it, vise the 3 I had in the older 18 hp fastwin. To remove the lower unit, I had to loosen the bolts for it and drop the unit an inch or two. The screw that holds the shifter shaft(sorry for poor terminology) in place was just inside, and exposed when I lowered the unit by that first few inches. <br />I'm sorry I can't post pics. This is my work address, and I don't have a computer at home anymore. I should learn to fix computers-more money in it-at any rate, I can't download pictures from work, so I'm stuck with what I have. Can anyone help me with what this motor is, and what the compression should be? I checked it and had 55 on each cylinder. I'm pretty sure that's bad, but I'm still learning. As always, your help is greatly appreciated.
