Andrec4016
Thread starter- Joined
- Mar 13, 2005
- 57
I have a 83 140 v4 rude and its been running fine per say when cold it starts with no problems and idles good but when hot it has the idle syndrome it stalls alot but run great at WOT, anyway this past weekend I was running low on gas so I stop at a marine put in 5 gals and I ran out of my regular oil, I mix a 50:1 with regular TCW-3 black oil.. the guy at the marina only had this pink stuff that he said it was made for Evinrudes and Johnsons well had no choice since my marina was 5 miles away.. So going back to my marina doing about 30MPH suddenly my engine quit no warning nothing the temp was higher than normal, so I let it sit for a few minutes engine almost didn't want to start it acted like a low battery and engine didn't sound very good slow revs and almost no WOT also knocking sounds, so I guess what I'm asking is did the mixing of oils cause this and is the only answer is to empty gas and start fresh and more than likely a carb rebuild? and what is this pink junk they sale anyway I've seen it in stores but to me oil should be black.. any help ?
